HD is different hardware to the Blue V2's, so you do need to buy a new unit for HD.
ok thanks. any idea on price and or release date?
Any updates on release?
Insite creates a 'template' which is just all T_ trim parameters with their values that it can update (not flash) via the CPP over j1939 protocol. A solution would be to read the ecm out, save all the trims, vins,etc to a seperate backup file specific to that vin. Add a tool for writing those values into a compatible file before flashing. Super handy for setting up a replacement ECM, or copying trims from one vehicle to another.
So much easier said than done :unsure:, but this maybe something we need to look in to down the track. For now this won't be an option though, if you want to keep the vehicles trim values as they were then you will need to use the tune you read out.
I have a feeling there is a command the ECM will acknowledge that sends back all the ID's for the trims that can be read / written. The whole concept of the trims is nice but it kind of got out of hand too.
Rather then start a new thread, I'll ask the question here.
I let a mate who is a heavy diesel mechanic/engine re-builder etc know about this and he wanted to know if you would ever support the following:
CM570, CM870,(EGR) CM871E(EGR) and CM871(DPF&EGR).
I have no idea what they are from, but i would assume highway (prime mover) trucks.
Our current plans are attached.
Cheers
Cindy
https://uploads.tapatalk-cdn.com/201...2f7c164c49.jpg
Sent from my iPad using Tapatalk
Does anyone have any Cummins OS files that they would like to share? I would just like to load the new software and open up a Cummins OS to look around in it to see what is there.
Thanks!
Of course we had a lot of files submitted during the beta phase (about 35 OS's supported on release) but as per our agreement with the beta testers we won't share any of those files.
What is in the tunes is pretty much exactly the same as the 2010+ Dodge Ram, just much bigger numbers :shock:
Attached is the read from one of our bench CM2250 ECM's from a wreck so I'm comfortable to post this up (FWIW I don't think this was a stock tune, some of the maps didn't seem right for a factory file).
Thanks for posting up what you have!
