Can I use the old AutoTap V1 (RS232) with EFILive still?
It is the AutoTap/EFILivePro version.
How do I get older versions of EFILive that work with it?
EFILive v7 does not work.
I think it is a AT1EFIPRO. I'll go check....
The latest version of EFILive works with serial and USB AutoTap cables. A change was made in this latest release to fix a bug that caused the AutoTap cable to not work. So previous versions will not support AutoTap but the latest one V7.5.4 will.
It is available here:
http://forum.efilive.com/showthread.php?t=8289
This one is RS232. It is a KAT1EFIPRO, the AT1 model.
Ideas?
Tom, try the V7.5 software in the link in post #2.
I'll give it a try tonight....
I found this here: http://efilive.com/faq.aspx
I have an AutoTap Scan Tool. Can I use EFILive?
Yes, you may purchase an EFILive registration key that allows you to use the EFILive V7 Scan Tool software with your AutoTap V2-AT1, V2-AT123 and ATU interface cable(s).
EFILive V7 is not compatible with AutoTap V1 cables KATUEFISTD or KATUEFIPRO.
The AT1 designation is not the version number.
AT1 means a GM specific cable.
AT2 means a Ford specific cable
AT3 means a Chrysler specific cable
AT123 mean a cable that supports all three manufacturers.
AutoTap V1 cables come in AT1, AT2, AT3 and AT123 versions, are black and are RS232 serial cables. (Not supported by EFILive)
AutoTap V2 cables come in AT1, AT2, AT3 and AT123 versions, are black and are RS232 serial cables. (Supported by EFILive)
AutoTap V3 cables support GM, Ford and Chrysle, are red and are USB. (Supported by EFILive)
Version 5
http://download2.efilive.com/Softwar...5SetupFull.exe
Version 6
http://download2.efilive.com/Softwar...iveV6Setup.exe
Thanks! I'll let you know how it goes!
Autotap hooked up me with the correct AutoTap registration info and EFILive's V6 registration info. They said that is what that one was setup for.
What vehicles can be used with V6?
