I have a wideband and use the ben factor,copy and paste deal to do auto ve tuning.Is there a way to create a similar map and ben for the maf table--maybe airflow/actual airflow to get value i can copy and paste to the maf tablr(hertz).
Try this...
This link may help.
http://efiforum.iqd.co.nz/showthread.php?t=671
I still don't get it ,all the maps i see are map vs rpm like the ve table .How do you copy the results to the maf table which is frequency(hertz).
open the map i poseted for you, then look at the properties. The data tab is the BEN flactor, Column is null, row = the MAF hz.
You will want to select the BEN factor that corresponds to your WB
Like TAQuickness said, look at the map as well as the maps posted in the link. They all mimic B5001
Taquickness,when i look at the map you posted column is map(kpa) and row is rpm ,isee no way to correlate this to maf frequency.
You aren't looking at the right map then. I just downloaded his map and it is right. :(Quote:
Originally Posted by ahall1
Dunno what to tell you. I downloaded the map and it looks quite right to me.
Open the tune tool and browse to {b5001}
Select every cell in the table, and press ctrl+shift+c or right click and copy with labels
Open the tune tool and select an unpopulated map
press ctrl+enter to open the map properties.
On the data tab, select your BEN factor
On the colum tab, press the paste labels button
On the row tab, select maf hz for the parameter, and press paste labels button.
OK i got it thanks Ta quickness
