1 Attachment(s)
E67 Oil Pressure and Temp
Working with OS 12618164 2008 Trailbalzer 4.2L LL8 E67. Unfortunately my BIN extracting tools will read E38 but not E67’s.
Looking for:
The LL8 uses an oil pressure switch at J3 pin 65 which doesn’t report actual pressure. I’m hoping there is a switch in this OS to enable J2 pin 60 like the V8’s.
Manual transmission option (like the E40) to allow DVT controls when running without the TCM since there are no matching OS’s with manual transmission to use for a segment swap.
Engine Oil Temp - Switching G1218 from Calculated to Sensor works. J2 Pin 65. Logs fine with EFILive but won’t log with Torq app (GM PID 221154)
