1 Attachment(s)
Turbo Silverado Cam Issues
So I finally got me the right cam for my 2004 turbo silverado even though its been running amazing just to make it most efficient and powerful and also wanted as much chop as I can get out of a single turbo set up (still havent had time to get that second cbb mounted and hooked up yet). Anyways, I have two main issues that I havent been able to figure out and another local tuner spent just a lil bit yesterday trying to figure it out and couldnt in the time we had and they are #1 It will not idle very well and once Its started and is idling if you hit the pedal at all it will then fight to run and die every single time so you end up two footing it to keep it running. which makes it extremely hard to drive stoplight to stoplight and it ran just like a brand new truck until you got into boost before the Comp Cam SGT100. #2 problem and is related to the first im sure is that i was warned this would be a choppy cam but thats what I wanted but its not choppy at all so far. However, we cant get it to idle clean and under 900. I noticed right away it was idling very rich and hoped that was the main issue as thats a quick fix and more rich here and there throughout and im still working on knocking that down lol. I did read through several threads that were close to what im asking help with but not exactly. I will post one of the test tunes for the new cam for anyone that would be kind enough to take a look and advise or just make some changes, explain and send it back for me to try. Or if anyone just has some ideas for me to look at that maybe we have not looked at enough that would be appreciated as well. Sincerely, Bryan Attachment 20466
