Trying to AutoVe but car wont run without MAF
I'm trying to do the AutoVE as per the tutorial but the car will start rough for about 5-10 seconds and then just dies right away and it wont start again period.
I tried all the parameters to see which one was causing this and when its when I set the MAF fail frequencies. All the other steps are done and the car runs good but it doesnt run without the MAF why is this?
The car is running open loop but not SD because of the MAF.
Also, the car has the following codes right now:
P1518 "Throttle Actuator Control (TAC) Module Serial Data Circuit"
P0108 "Manifold Absolute Pressure (MAP) Sensor Circuit High"
Could this be the causing problem? These codes only poped up after I started using EFILive and I dont know what it really means.
:help2:
