Quote:
Is there a way to get these outputs working on all systems?? If I am correct the ECU will turn these off if the engine is in a non running state regardless of key position? If I am correct and I can get these outputs working. I will use them to fire a relay to turn on the innovate. thus solve my forgetfulness issue, no noise from motor, then no power to O2 sensors!!
My understanding, prior to 2004, is that HO2 heater power is always on while key is at RUN position (regardless of engine running or not);
