2 Attachment(s)
> > > RoadRunner FAQs < < <
Attachment 4906
http://i235.photobucket.com/albums/e.../RTACS-1-2.gif
Most of this is obvious stuff but, maybe it will help a few people. :)
Connect/Disconnect to RR step #1
Download/Upload tune file step #2
Emulation on/off - must be on for RTACS to work :doh2:
Filter Sets - at least 1 filter must be configured
RR Control Panel - displays the control panel, technically step #1 :hihi:
Enable/Disable Edit Mask -select this, then highlight the cells you want untouched by RTACS,
then add the selected cells to the Edit Mask
Fine/Course Control - set values in the Roadrunner properties tab,one of these must be selected for RTACS to work
Column Data - value of linked PID from cal.link.txt
this must match the column data of the table you want to use RTACS with
Row Data - value of linked PID from cal.link.txt
this must match the row data of the table you want to use RTACS with
Data for RTACS - value of and, the linked PID that will alter the table with RTACS ,
if there are no values in these boxes you must configure the cal.link.txt or,
the PID linked in the cal.link text is not selected in the scan.exe
Accuracy % - cells stop adjusting within this limit
Minimum RTACS Limit - cells values will not go below this limit, if idle is rich try dropping this value
Maximum RTACS Limit – cells values will not go above this limit, make sure this is not too low when doing WOT tuning
http://www.gifmania.co.uk/Looney-Tun...r/roadrun1.gif
cal.link.txt editing:
RTACS supports Addition, subtraction, multiplication and division as well as the current BEN factor percentage adjustment.
Just add the operator (+, -, * or /) you wish to use followed by a comma before the first PID name in the *.RRR key like this:
Bxxxx.RRR=+,<pidname> Leave it blank to use the standard BEN factor %.
Example #1:
;Desired Airflow
B4307.ROW=SAE.ECT
B4307.RRR=+,CALC.RAFIG,CALC.RAFPN,CALC.RAFACIG,CAL C.RAFACPN
This will ADD+ the logged RAFIG amount to B4307.
Example #2:
;High octane spark map
B5913.ROW=SAE.RPM
B5913.COL=GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYL AIR,CALC.CYLAIR
B5913.RRR=-,GM.KR
This will subtract- logged KR from B5913
Attachment 4695
