Originally Posted by
Chuck L.
I said:
"The injs are getting pulled and cleaned. I'm not doing this again!"
Witchhunter said:
" that no amount of cleaning will fix up the 454 injectors. Get some LS1 or LS6 injectors, update the injector size and you are set."
He is right!:)
I have an ASNU bench. I leak tested them. 5 of 8 leaked. I cleaned them for 4 -10 min cycles, put them on the bench, and they "appeared" to be OK. I then re-installed, hit the key, and whamo 5 leaked. NOT! :mad:
The new injs are $95.00/ea. The customer nearly had a stroke when I quoted him the cost!!
I have a couple sets of 19# firds, from a 302. I recall they are 19# @ 3 bars. At 58psi, they should be really close to the 24PPH I got when I flowed the originals...[22#]. Do those numbers sound close??
Thanks for the headsup!...;)
