It wouldn't lock because my airbag sensor went right just wanted to double check before I started looking for a new ecm
If you had a communications error because of something interferring on the can bus, or because something was mechanically unsound you would not be getting an error code that detailed the ECM was locked.
The error code list isn't generic - there are 41 very detailed pages of error codes breaking down the errors received.
Cheers
Cindy
We have ecms that i can load your tuning onto and send it. Call for the costs. Most likely your ecm will be a repairable core but i can put it on the bench harness and see what is up with it.
Could it be a software update issue if my trucks software is out of date or if the efi live software is out of date
