01z06
because all the data is now under fuel - dynamics section.
01z06
Well, I think I got it sorted. I modified the .cax and removed all the overlapping addresses from post 1.
B9014 and B9021 are the ones that confused me the most because they had the same address but different type, units and factor.
+1 delete B9014 and keep B9021.
Made a few minor changes to the folders.
Joecar, please move this thread to the .cax forum if you want.
Jesse
Ok, moved.
I got the ".cax errors" after upgrading to build 235, OS is 12212156. Error loading B9000, B9003, B9006, B9007, B9011, B9012, and B9100. Only B9100 is actually in the tune, Lean Cruise enable. How do I get rid of the error messages? And will I trash my PCM if I load a tune with EFILive giving me these error messages? I have the latest 12212156.cax file.
Use cax b above, it's for 12212156 os with the overlapping addresses removed.
Ok, that worked (no more error messages), but B9100 is gone - Lean Cruise Enable. So is LC enabled all the time or never? Thanks.
LC is enabled only if you enable it and do a full flash, and set its operating parameters correctly.
