Can you post up the log file of your RR.
i have not saved a log as they seem screwed. I have my tune setup for the RR if thats what you need
I was just going to see if your log acted the same way on my laptop.
See if you can track this log with your software.
yep it shows up alright. I show a line through my ben title since I used a lc1
my issue seems to reside in the tune tool refusing to leave the 15 kpa column. if it would go to other cells like the scan tool shows when recording I would be set.
The log I posted up tracks fine in the tune tool on my laptop,did it track ok in your tune tool or was it still stuck on 15kpa.
humm.. i did not try. I wasnt aware I could do that.
As long as the table in the tune has the same axis as the tune that was logged it should still track in your tune file.
ok, took me a little but yes, your log is doing the same thing in my tune tool as my log. it only shows the first column during play
Have you tried maybe reinstalling the software or upgrade to the latest version if you have not already.
i upgraded with no change, uninstalled rebooted installed and rebooted with no change im at a loss. somehow its saving the problem
