Hey guys im somewhat new to efi but i have a few good tunes that i had been running before i got the switch. I was wondering if im able to convert these to dsp format and put them on my switch or what do i need to do? Thanks.
No you are not gonna run tune for tune. Only a few tables can be modified beyond the stock tune. You pretty set the stock tune which can be any tune you like the best way needed and modify the few tables for each DSP 1-4 for differences. There is a doc on the site describing DSP setup. Read through that to get you started.
Brian
Oh okay thanks thats what it seemed like i read through it but couldnt find a definite answer. So i can set my main tune as the stock one and switch from there, is copy and pasting tables alright to do?
Yep no problem copying tables from one to the other. Just open up two seperate Tune apps and bring them up. Then cut and paste from one to the other.
Brian
