Idle surge coming to a stop
This is on a OLSD tune.Been having this problem on 3 built cars that are all 00 Camaro's.I'm ussing different base files for 01 +02 Camaro's with the same problem.
The cars all have the same problem. 50% of the time they idle fine when coming to a stop.Then for no reason coming to a stop they will drop idle to 200-500rpm or all completely die.The A/F's are set to 14-1 to 15-1.Timing base is holding at 24-28 degree's.Cars are showing no signs except extremely slow IAC count at idle -sometimes.
I've adjusted all throttle follower and cracker tables with no fix.
any idea's? I'm starting to think the base 2000 computer is the problem.
