Writing my DSP5 Tune
I wrote a dsp5 tune for my LB7 and its all done and I went to put it on the truck and that went smoothly but it seems like only the base file took when I switch the tune its seems like it is just a single tune, I did check the switch and it works any help??
Did you attempt to read out the calibration to see if it took?
Did you do a full flash?
I did full flash it and what so you mean read out the calibration? when I do the full flash the truck takes the base file you van see that in the pids list and feel it in the drivability but it doesn't take the other tunes
I mean after you have flashed the DSP file, have you attempted to read it back out to see if loaded properly???
Ill give that a try and let you know what happens but good thinking
