Is BBL added for all supported Cummins or is it just for the 06-07 Cummins at this time?
BBL is ONLY avail when running csp.
If you have an Insight monitor and when Edge releases the update to allow CSP5 tune switching, you will be able to use that. If you have an Edge tuner (the Original Juice with Attitude, Evolution, Etc) then you will not be able to switch tunes with that hardware.
The SoCal Diesel CSP5 switch connects to the OBDII port, you can also use the other switching solutions noted above, or use your V2 or Autocal.
Once you switch tunes, you could disconnect whatever device you used to switch with, and the tune selected will remain selected.
(As far as I know on all this, I'm sure someone will correct me if I was incorrect anywhere)
No edge implementation anytime soon...looks like my insight may be a paperweight!!!
Subd
Timing calculator will be added back for our next release.
Cheers
Cindy
Called Drew Tech this morning and the cust svc guy had no clue what I was talking about.
To be fair to Drew Tech, we've only been dealing with the guys in the Tech department, what they are working on may not have flowed through to the customer service people.
Timing calc will be in the next update (to cover all CSP tables).
There is no need to leave a switching device in the truck (such as a V2), the tune is never forgotten once selected, even if you disconnect the battery! The only time the tune changes from what you last selected is if you reflash the truck, unfortunately that is just what the ECM does after it reinitialises itself after a reflash.
I get a "Error: $0194: Write failure." When I try to program the Black V2. It goes through fine on the Blue V2
