I'm getting my V2 on Monday, and I was wondering if I can command the torque converter for troubleshooting purposes?
Yes you can.
Ok, Thank you
I should have asked you this first: which trans do you have...?
Allison 1000
Ok, got my EFI live v2, but I can't figure out how to command the torque converter. Does anyone know how to do this?
Start scantool, File->Select Controller (select your flavor of Allison), File->Connect, goto DVT tab, select your Allison controller, click Activate, goto Gear tab, checkmark TCC Solenoid, click Turn On.
Be careful, use common sense.
Is your Allison an AL5 or A40...?
A40.
When I connect to the controller though with EFI live 7.5 scan tool, I do not have any supported PID's for transmission. Any idea why?
http://images.tapatalk-cdn.com/15/07...eb9851aede.jpg
Do this:
- On the PIDs tab, uncheck Supported;
- File->Select Controller, and select A40 Allison 6 Speed TCM;
- File->Enter VIN, and enter the VIN;
- Info->Validate Pids, and let it complete;
you should now see a bunch of pids.
