Can you update the Main VE and Boost VE at the same time or do i need to just have one turned on at a time?
The reason i ask, is when i have both enabled the 105 column on the boost VE table updates below 105... Does that make sense?
I'm not sure, but it seems to mean that you can only have one table active at a time... (I haven't played with my RR sufficiently).
Well i was able to figure it out. It took awhile. Basically you have to build a custom pID for each table. You also have to build in a MAP check to filter out MAP settings above/below the table boundaries. Once i get back to my laptop i will post up the PIDs if anyone is interested.
I'm interested, please/thanks.
I did a write up on PerformanceTrucks.net
http://www.performancetrucks.net/for...6/#post5084192
