I need a 3 bar map sensor for my 02 T/A. Anyone know a gm part number that will fit the ls1???
I found this on LS1 tech:
3-bar MAP sensor(AC-Delco#213-1562)=12223861(formerly 16040749, AC-Delco #213-101)
pigtail harness for MAP sensor (AC-Delco #PT1035) = 15305891
Where can i get these?
GM dealer or GM dealer parts store online or AC Delco online.
Which of these part numbers are good for a plug n play, or close, 3 bar map sensor?
I believe speedinc has them with plug and play harness, but they won't fit in the factory location so you will need to run a vac/boost line to it.
