Are you going to release your final version cax file on GitHub?
The post stuff? Not sure. There is no real way to see if they work. There is no PID which will tell you how much each injection gives.... Because grr Bosch. On the plus side, they should *work*.
easy to calculate by total injection mm3 on stock, then on tuned while engine cold then later on warm.
maybe 5.24 mm3 on idle stock
maybe 4.24 mm3 on idle tuned
equates to 1 mm3 reduction total
All this for Post1 injections while engine cold and warming up.
But iam not sure if this works, just talking out of my head :)
Then it'll need more fuel to maintain the same conditions... You may not see any change at all other than a bit more noise.
Ross, I have a question for you.
So I want to make the cax have the fancy giant DTC tables that you make...
For example I have this.
But the issue is A. It gives unrecognized PCM error, and B. The values aren't right cause they just start from 392C0A, the first address. The good news is it does fill in the descriptions for the codes, and loads about a million times quicker on my laptop.Code:[B9575]
DESC.001 = Test Table
VIEW = 4 "Test Table" "Diagnostic DTCs" "DTC Type Table" 1 4 0 0
ADDR = "392C0A,392950,39294E,39294D,392BA6,392B8E,3929F2,3929F1,392BD4,3929CB,3929CA,392848,39283B,392BBA,392960,39295F,392BDF,392BDE,39295C,392BC5,3929CD,3929CC,392BDD,392BDC,392C11,392B9D,3928DC,392BA7,392B9E,3929A4,3929A3,3929C7,3929C6,3928F3,3928F2,392B87,392B23,392955,392954,392A8A,3927C2,3927C1,392942,392941,392BA8,3929AE,3929AD,3928B7,3928BB,3928BA,3928BE,3928B8,3928BC,3928B9,3928BD,392B20,392A70,392A73,392A71,392A72,392803,392929,39292C,39292A,392B84,3927C0,3927BF,39292B,392802,3928B3,3928B6,3928B4,3928B5,392BD0,3929DD,3929DB,392C63,392861,392860,3929D9,392C1A,392C16,392C19,392C17,392C18,392A3D,392C0C,392C0B,392C09,392C08,392946,392945,392BDB,39278E,39278A,392BE6,392916,392915,3929CF,3929CE,392C5E,3929D1,3929D0,3928CF,392C0E,39293D,39293C,392BAD,392BF1,392910,39290E,392BAB,3927EF,3927EE,392B5B,392994,392993,3928,3928DF,3928F8,3928FA,3928F9,3929D5,3929D4,392A89,392A88,3928EE,3928ED,3927A1,39279E,39279F,392793,392AD9,392B82,3928F0,3928EF,392C20,392B5E,392BB3,392BB4,3929C1,3929C4,3929C3,392C2C,3.928E+12,3.928E+11,3929A9,3929AC,3929AB,392BAE,392B58,392855,392BA3,39280000,3928000,392872,392BB5,392B8F,392856,392873,392874,392875,392876,3927C3,392937,392857,3927A3,39298D,39298F,39298E,3927AB,392B27,392A3F,392A40,392C5D,3929FF,392BD6,392A05,3929FA,3929F8,392AAD,392C5B,392B52,392A90,392A93,392ABA,392ABB,392AA1,392AA0,3928C3,3928CB,3928CC,3929DF,392BB1,3929DE,3929DC,392BE7,392BEA,392BE8,392BE9,39299A,392B95,392B9F,392A20,392A1F,392B92,392912,392B80,392B81,392911,39290F,39290C,3927B7,3927B8,392BB2,392C4A,392B5F,3927A2,392884,392B8D,392B5A,39287B,392890,392B59,392894,392892,392893,3928D1,392BD1,392A22,392BD2,392A21,3929D3,3929D2,3927CA,392852,392BC2,392BC3,3929F9,3929F7,392A01,3929B6,3929B4,392ABD,392BC6,392A0B,392BC9,392BE3,392BE4,392BC7,3928D9,3929FD,392A03,392AC1,392A06,392A04,392885,392886,392887,392888,392889,39288A,39288B,39288C,39288D,392C60,392C62,39284E,392BAC,392AB2,3929B1,3929AF,3929B2,3929B0,3929C5,392A67,392A68,392ACC,392C5A,392853,392BC0,392854,392BC1,392ACB,392B98,3927FA,3927F9,392B9A,392AA3,39288E,39288F,392868,392869,392AC9,392ACA,392925,392924,39294B,39294A,39294C,392BBD,392997,392999,392998,392B93,39299E,39299D,392BD9,392B9B,392AB9,3927FD,3927FC,392B9C,392AA9,392A9C,392A4A,392811,392BE5,3929D7,3929D6,392BB6,3929A8,3929A7,392BFC,3928D2,392BE0,39290A,392909,39280A,3928D5,3928D7,392BFD,392BEC,392C48,392BED,392819,392C49,392818,392C44,39281C,392BEE,392BEB,3928EC,392BA5,392AC2,392BB0,392C10,3929F4,3929F3,392863,392864,39291B,392C59,39295B,39295A,392939,39293B,39293A,392B2A,392B2D,392B2B,392B2C,392951,392ABF,3927F5,3927F4,3927EA,392B97,3927D2,392BB8,3927CF,39270,3927D0,392BB9,392BBB,392BB7" 0 8 UNM 0
SI_SLOT = Number 1 0 0 0 256 0 256
SI_ROW = Stuff "P0016,P0030,P0031,P0032,P003A,P0045,P0047,P0048,P0053,P007C,P007D,P0087,P0088,P0090,P0091,P0092,P0097,P0098,P00C9,P00CA,P00EA,P00EB,P00F4,P00F5,P00F6,P0101,P0102,P0103,P0106,P0107,P0108,P0112,P0113,P0117,P0118,P011B,P0128,P0131,P0132,P0133,P0171,P0172,P0182,P0183,P0191,P0192,P0193,P01CB,P01CC,P01CD,P01CE,P01CF,P01D0,P01D1,P01D2,P01F0,P0201,P0202,P0203,P0204,P0234,P0263,P0266,P0269,P026A,P026C,P026D,P0272,P0299,P02CD,P02CF,P02D1,P02D3,P02E0,P02E2,P02E3,P02E7,P02E8,P02E9,P02EB,P0300,P0301,P0302,P0303,P0304,P0315,P0335,P0336,P0340,P0341,P037A,P037B,P0381,P0401,P0402,P0403,P0405,P0406,P040C,P040D,P040F,P041C,P041D,P0420,P0461,P0462,P0463,P046C,P0480,P0489,P0490,P049D,P0506,P0507,P0513,P0522,P0523,P0532,P0533,P053A,P053B,P053C,P0545,P0546,P054E,P054F,P0562,P0563,P0564,P0567,P0568,P0571,P0575,P057B,P057C,P057D,P0601,P0602,P0606,P060B,P0615,P0616,P0617,P061C,P0621,P0622,P0627,P0628,P0629,P062F,P0633,P0641,P0645,P0646,P0647,P064C,P064D,P0650,P0651,P0671,P0672,P0673,P0674,P0691,P0692,P0697,P069E,P06DA,P06DB,P06DC,P0700,P0703,P0851,P0852,P0856,P1043,P1044,P1046,P1048,P1049,P1089,P10CF,P10D0,P11A6,P11A9,P11CB,P11CC,P11D3,P11D4,P11D7,P11DB,P11DC,P122C,P122D,P122E,P122F,P1248,P1249,P124A,P124B,P125A,P125B,P128E,P12B0,P12B1,P1400,P1407,P140B,P140C,P140D,P140E,P140F,P144E,P144F,P1472,P147F,P150C,P155A,P161A,P162B,P1631,P163C,P163D,P1649,P167C,P16AD,P16AE,P2002,P2008,P2009,P200A,P2010,P2032,P2033,P203B,P203C,P203D,P2047,P2048,P2049,P204B,P204C,P204D,P204F,P205B,P205C,P205D,P2080,P2084,P208A,P208B,P208D,P20A0,P20A1,P20A2,P20A3,P20B9,P20BB,P20BC,P20BD,P20BF,P20C0,P20C1,P20C3,P20C4,P20E2,P20E4,P20E8,P20E9,P20EE,P2122,P2123,P2127,P2128,P2138,P2146,P2149,P214F,P2199,P21AA,P21AB,P21AF,P21B0,P21DD,P2200,P2202,P2203,P2205,P2209,P220A,P220B,P221C,P221D,P221E,P221F,P2228,P2229,P2237,P2243,P2251,P2263,P227B,P227C,P227D,P2294,P2295,P2296,P2297,P229E,P229F,P22A0,P22A1,P22A3,P22A7,P22FA,P22FE,P2428,P242B,P242C,P242D,P2453,P2454,P2455,P2457,P2459,P245A,P245C,P245D,P2463,P249D,P249E,P24A5,P24AE,P24AF,P24B1,P24B3,P24B4,P24B6,P24B7,P24C6,P24C7,P24D0,P2500,P2501,P2505,P2510,P2544,P2564,P2565,P2598,P2599,P25BD,P262B,P263A,P263B,P2687,P2688,P2689,P268C,P268D,P268E,P268F,P2A00,P2BAA,U0073,U0074,U0101,U0106,U0109,U010E,U0121,U0140,U0198,U029D,U029E,U02A3"
Care to throw me a bone here? It would work if they were all in a line, and I could just use one address, but you know that won't work here without lots of empty tables.
ACtually have the same issue on another controller. Trying to properly display/edit a DTC table and make it look decent. A bit tricky via cax :P
So if we have 126589.bin and 12662377.bin how do we open them. do we need to combine them and import it to an efi live? i thought efi could handle raw bins. I imported your cax files and it wont open the raw binaries
Don't combine them. Try opening them with the V8 tool, if that doesn't recongzie eitheir then there's something wrong with the bins. If it does, you didn't install the .cax files correctly.
