I've deleted the Vats, applied the patch, disabled the starter relay diagnostic. The engine will start, then immediately shut off like the vats is still active. Any help appreciated!
Did you do a full flash of the ECM once the patch was applied?
Did you change the starter type?
I'll have a look at the file you posted.
Customers are always impatient, don't stress :hihi:
Out of interest, have you checked the DTC's after you've attempted to start/run the engine?
Also, these cut fuel and spark for VATS, might be worth a quick look to see if it is cutting spark when it dies, if it isn't then it might not be VATS related.
Ok so as I was saying, these ECM's cut fuel AND spark when VATS is active.
Did you check DTC's after the engine shuts down?
