OS 12644094
VIN 1GT121C88DF102946
looking for a stock file didnt know if anyone had one thanks for the help!
OS 12644094
That Vin is a 2013 or 2014 model LML
its a 2013
Still looking for a file to match these segments Attachment 23293
Hi, OS 12644094 in a 2013 normally mean the ecm was flash with a H&S delete file, OS 12644094 was a very early OP in model 2011, H&S used it on 2011,2012,1013 truck
any idea what the correct os should be then? and will that os work fine to flash it back with then?
When you need calibration info , go to https://tis2web.service.gm.com/tis2web/
input your vin, choose ecm , and you will see the latest calibration release for the vin
Attachment 23295
you can look here https://www.dropbox.com/sh/uujqht8m8...nav_tracking=1
to search for a file that match your needs, keep in mind that efilive can't make a backup of the actual ecm calibration , downloading a file to the ecm will overwrite the data
