Jim,
Your p1 is now in eh? Also the 230 cam. What you putting down if so? So jealous as this is the way i want to go. Are you on stock heads as well?
regards gav
Jim,
regards gav
I've had the Cam in for years, lovely lope to it and very good for N/A, probably all sorts of wrong now that I've got the blower on (too much overlap), but that's the joy in having a surfeit of power . Heads are stock, but now the blower is on and working well (pushing 7 psi currently) I'm certainly not chasing any lost HP!
I've put on about 3K miles this year post blower install, so it's about time I did a dyno power run I guess just to see where I got too (I never had an absolute number I was looking for, it was primarily the challenge of making it all work) - at a guess? Just shy of 600 fwhp (or bat shit crazy in a 1 tonne car ;-)).
Jim
surfeit of power is still insufficient (you can never have enough power)... :w00t::angel_innocent::laugh::thumb_yello:
Hello again,
had time to browse here and ls1tech and maybe my problem with cruise control feeling might be that my tune is for an auto, but my swap is a t56 6 speed manual. Looking at other posts my op system may not support a segment swap or whatever that is and if i do change to a manual tune do i need more pcm inputs like clutch? If so that maybe a piarse as loom doesnt have that in. Op system is 12208322 and isnfor a 6.0 auto. Mine is 5.7 and with a 90mm tb.
any ideas on what is best to do? Open another thread?
regards gav
