2005 GTO ECM to PIM Linking, or how to be frustrated for 3 days!
Have this fine 2005 GTO with a bad PCM. Looks like they are NLA so I had a used one, programmed it properly off the SPS site but I have tried for 3 days to relink the ECM to the PIM with no luck. Been on the phone with the fine folks in Detroit for 2 afternoons, they've had me try 3 different laptops with 2 different operating systems and 2 different J2534 passthru tools with no luck. As soon as I click the PCM to PIM relink button the utility fails almost instantly. I even have the IMMO number for the car but I can't even get to that screen to input the number. I tried programming and using the original ECM but that fails the linkup too.
I'm SOL so I removed the VATS and all of the relevant codes, the car starts and runs perfectly with no check engine light but after 3 seconds the service engine soon wrench comes up in the instrument cluster. I can simply hit the option button on the cluster and everything goes away but I'd still love to get this one correct as it is a customer pay car.
Is there any way to perform the relink through EFIlive?
Any suggestions would help.
Don't throw away those E40 PCMs they should bring good money anytime soon.
Thanks!
