I updated to the latest software update and now my copy and paste function no longer works! Isthis something in the latest update or in my PC screwing up? :mad:
A few more specifics please, what are you trying to copy/paste?
I am trying to change pilot injection quantity on quantity base and then copy and paste that to the air density 1, 2, 3 ect... hope that explains what i am trying to do. It has always worked for me when copying and pasting until yesterday when I updated the system.
I use to be able to copy the timing tables and paste them on the air density tables 1,2,3 ect as well and now I am no longer able to do that either. Maybe it something wrong with this new PC I don't know but i appreciate the help.
So was this a dumb question or what ?
Hey longcummins, if you are copying the entire table I use hot-keys, Ctrl A to select all, Ctrl C to copy, then go to your table 1, Ctrl A to select all, then Ctrl V to past. Give that a shot.
Sam
Cool deal I will give that a try when I get home this evening.
You should be good to go, I have not had any problems with any table that I have done with the above procedure.
Sam
Yes that doesn't work either. I get this thing that comes up and its saying something about running scripts files. Then looking into that it seems its all about GM products LMM LBZ ect.... and DSP 2 and DSP 5 so I dont understand what I may changed unknowingly. Still trying to figure this out. Thanks for the help 30RUM.
If you don't mind me looking at the file, you can send it to me and I can give it a try. That would eliminate any computer problems. I just had no problems copying and pasting in an LMM & LBZ file both DSP5. Strange, my email is samk408@msn.com
