Originally Posted by
Blacky
There is either a mis-configuration in either EFILive's PID configuration for that PID, or GM is being inconsistent in its use/definition of that PID. It is defined as a 16-bit wide field in EFILive's software. However the trace shows that your ECM is only returning an 8-bit field. If all E86 controllers return an 8-bit field, then EFILive's config is wrong and we'll fix it asap. I.e. if all E86 controllers cannot log that PID using EFILive BBL then we have probably got it wrong and need to fix it. If one or more E86 controllers can log that PID using EFILive's BBL then we'll have to make a special hybrid definition of both 8 and 16-bits.
Have you successfully logged that same PID on any other E86 platform? If so what operating system number was that?
