June 2020, Beta Release - Release 3
ATTENTION - BETA SOFTWARE RELEASE
We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
The current public release is available here.
Fix Summary:
Changes to V8 software
- Replaced USBView.exe utility with the more comprehensive USBTreeView.exe in the Drivers\Utilities folder.
- Updated OBD error codes and messages in the $0300..$03FF range.
Changes to V2 firmware (V2.07.163)
- Update to ensure all TCM controllers do not require a VIN license to be flashed.
Changes to V3 firmware (V3.00.043)
- To protect the integrity of files on the device, any attempt to read, modify or delete any file or folder using EFILive_Explorer.exe while a black box operation (read, flash or data logging) is in progress, will be rejected with the error $010C "Device is busy".
Full Release Notes:
Version Numbers:After installing this beta release you should have the following software and firmware versions installed:
- EFILive V7 software: V7.5.30 To view the installed version, select Help->About (in the V7 Scan or Tune software).
- EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
- FlashScan/AutoCal V3 Firmware: V3.00.043 (Jun 26, 2020).
- FlashScan/AutoCal V2 Firmware: V2.07.163 (Jun 24, 2020).
Download here:
Known Issues: Issue #1:
None
Workaround:
N/A
Regards,
The EFILive Team
