Does anyone have a supported vehicle list for EFILive V6?
If it is OBD-II with VPW protocol (i.e. 1997-2007 GM), then there's a good chance you can log from it.
Is V6 scan only or is it flash and scan?
I got the impression it would flash too, that is what it was originally bought for.
Tom,
V6 flashes also.
You can upgrade to V7 software (you will need to get a new cable registration license).
All the software is free.
You have FlashScan V1 that you run V6 on, right...?
Got it working with V7.5, so far at least, it does support the AT1 RS232 interface.
Now to see what I can do with it....
But on the V6 question, it flashes, but what vehicles? I can't find a list anywhere. I have the v7 scan license.
You won't be able to flash using the AT1 interface.
To flash, you need a flash+scan license, and an unused PCM license.
Flashable Vehicles: http://www.efilive.com/supvehicle.aspx
Mine is a AT1 V2, which means it will flash. Not to be confused with EFLive V2. It is the 2 way version..... I guess I will have to try!
Oh, I see.
EDIT: it won't work.
