Sounds like you're viewing in Lambda, no Equivalence Ratio.
The article starts with numbers higher than 1 giving a lower AFR.
It`s the opposite with mine, tables B3605 and B3618 contains multipliers lower than one.
Anyway, I`m struggling to obtain auto tune using RTACS on standard calibration file.
I`ll start a new thread describing the case.
When you view your B3605 and B3618, look in the panel in the upper right, next to Units, what does it say (EQR or Lambda, which one)...?
See what darcy said above.
You already know that Lambda = 1/EQR
and that Lambda < 1 is RICHER than stoich, and Lambda < 1 is LEANER than stoich
(and of course, EQR is the inverse).
B3605 and B3618 are not simply "multpliers", they are EQR or Lambda (depending on how you set Fueling Units in your tunetool).
Changed it under properties and restarted program.
Now it shows EQR, and the tables changed to higher than 1
