Engine misfires under medium and full load, and sometimes under steady conditions.
Advance and KR behaves strange.
Could it be a sensor fault?
Attachment 18314Attachment 18315
Also post your tune file.
What engine mods...?
Std tune. Cleaned main terminals on battery and main grounds. Also cleaned connectord to Pcm.
Checked for leaks on manifold - none. Also coil #5 was misfiring periodically under load.
I think a bad ground connection caused the 45 deg retard on ignition.
The bad coil also really made it cough and perform bad. It's ok now, only a few occational high rpm misfires on first gear
@wot. Possibly the plugs
