What are the pids for Ben Factor for WB innovative?
I think I found WB 02 AFR.
What PID do you read to make sure your tune has failed the MAF and you don't need to pull the yellow wire?
Thanks so much.
Thanks so much.
For E38 using wideband serial comms : CALC.WO2AFR1, E38.AFRATIO.DMA, CALC.BEN1_E38.
The MAF is failed if the ECM sees any of these DTC codes: P0101, P0102, P0103.
Also see here: showthread.php?8961-E38-VVE-Setup-Guide
