On a 2016 Silverado, after reading codes, reading tune, modifying and flashing I now get a warning about ice and 32 degrees readout on IPC
Is this normal and how to reset?
Think I may have found the answer:
https://ww7.oemdtc.com/2026/diagnost...-chevrolet-gmc
I had that happen once with the e92 reprogram. I disconnected the battery and crossed the power and ground to completely drain all the modules. Then everything re-synced and all was fine. Hope yours is that simple.
Thank you and that's worth a try to see if it can speed things up albeit there may be minor other consequences to that procedure (radio stations, time, fuel trims, codes) but maybe not. :cheers:
