Ive tried and with the tables we have access to I could not get it to do what I wanted. I know Kory is doing them and I know H&S does it, I am assuming there is extra tables in there (havent had time to look through mcc to see if they are listed with their software).
Here we are 5 years and some months later from the original post, and I have a 2012 I’m trying to get to keep the vanes open at idle. You can barely touch the throttle (not even enough to raise the engine RPM), and they will open right up to the open loop position table settings. Also, you can put it in reverse, and they will open but close in drive. It doesn’t make any sense to me. I could use some pointers if anyone has some guidance to help.
