Has anyone attempted to or successfully used an 06-07 5.9 oem ecm to run one of these engines on a stand?
I don't see why it won't work.
Flash a manual OS and disable all dtc that come up.
I was thinking the same thing until I looked at my first manual os yesterday and realized they have all the auto trans tables also. Not sure it even would matter. Should be as simple as hooking up appropriate power and ground, all necessary sensors, and can bus and a data link for tuning and it should run
It should not be a problem other than without a speed signal it may think that it is in idle mode and give you some MM3 limiting. We have fought with this in our pro-street truck, and have been able to tune around it so far.
Yes. Same standalone we have for the pull trucks.
any 06/07 5.9 ecm
interested in knowing if you can make an 03 ecm work as the same as an o6 ecm in a race only truck ?
Sure you can. It would be easier being there is already standalone harnesses out for 03-05
Im trying to do a bench flash and have all the wires connected to ecm properly and was wondering if any of yall could tell me what wires i need besides the 2 can wires from ecm and what places to put them in the diagnostic connector
