1 Attachment(s)
Known issues with Feb 09, 2015 release of the EFILive software and firmware.
Currently known issues and possible workarounds for the Feb 09, 2015 release of the EFILive Software and Firmware
- Software: V7.5.7.277
- Software: V8.2.2.271
- FlashScan/AutoCal firmware: V2.07.78
Issue 1:
Workaround:
None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
Files that are to be copied to FlashScan or AutoCal may not contain commas in their names.
Workaround:
Remove all commas from filenames prior to attempting to copy them to FlashScan or AutoCal. Will be fixed in the next update.
Issue 3:
Images are too large on the folder buttons in the [F8: Tools]->[F2: Search]->[Browse] tab page. That also causes the text on some buttons to wrap incorrectly.
Workaround:
None - it is a visual problem only and does not affect the operation of the software. Will be fixed in the next update.
Issue 4:
Saving Cummins CMD/CME tune files using the V7 software removes the VIN from the file and reverts it to "N/A".
Workaround:
After saving the file using V7, open the file in V8 and change the VIN back to its correct value on the [F3 Tune]->[F4: Properties]->[Controller Information] tab page. Will be fixed in the next update.
Issue 5:
Logging scan tool data using V7 pass-thru when the PID selection includes calculated PIDs will cause log file data corruption.
Workaround:
Exit from all EFILive software.
Download the attached obdiiV7.zip file and unzip it into the folder C:\Program Files (x86)\EFILive\V7.5 (overwrite the existing obdiiV7.dll file).
You will need administrator privileges to overwrite the obdiiV7.dll file in that folder.
