416ci (LS3) 12.4:1 CR, race gas to pump gas?
Hello,
I'm interested in purchasing a Corvette that has been heavily modified for road course/track use. The engine is LS3 based, 416ci with a 12.4:1 compression ratio and runs strictly off race gas, it puts out 800 hp. My question is if it would be possible to modify the tune to run off pump 91/93 gas without having to lower the compression ratio or change engine components? It is a deal breaker for me as race gas is $11 per gallon, and at $200 per tank, that makes the car too impractical for me. But if I can switch between tunes, for street (91/93 octane) and then track (98/100 octane), I could make that work. What are your thoughts and opinions? Thanks in advance!
Quote:
Originally Posted by
n8dogg
Dynamic Compression calculates as 10.56:1 per the specs I have.
We have e85 here, would I be better off running that?
Seems high, what is the IVC @ 0.006"
Yes no problem with 93 either just keep ethanol fraction above 30% (e30). e85 is 1/10th price of the other cocktail so yeah.
74.4 cc pour volume so pistons are 5.5cc dished. Nominal CR is 12.43.
If ICL = 108 then DCR = 9.5 to 9.9
If ICL = 103 then DCR = 9.9 to 10.3
Need IVC @ 0.006" to be accurate, but at a guess DCR is 9.5 to 10.3 (safe combustion of 93 really depends on squish / quench of piston), so possibly OK but yeah tune needs safety margin / limiting for daily on 93.
E30-E85 is all good.
