Bug in V.7.3 or in V.7.4?
Hi,
I'm going to do an engine conversion (2006 LLY). Using EFILive V.7.3 I read my ECM (Bosch#12606127), disabled VATS and flashed the changed tun-file back to the ECM.
After upgrading to EFILive V.7.4 I loaded the changed tun-file again and it says:
VATS enabled! I read my ECM again and it says also VATS enabled.But the tun -file history says:Anti Theft, changed from "Enable" to "Disable". Very confusing!
I can't testrun my engine yet, so the big question is: Is VATS really disabled by using V.7.4 or is there a bug in the software ?Thank you.
Kai
