Is there any way to resize the tune maps to fill the whole screen or larger to make the numbers/tables/screen easier to read?
If you plan to do some elaborate work on it, I guess you could always copy & paste to Excel or something ...
I just want to be able to enlarge the maps to be able to read them from a distance, even on a 20" monitor they are hard to read only a short distance away.
You could change your screen resolution or mess around with the Window's font settings. Should be easy to read on a 20". I keep mine set at 1024x768 for readability purposes.
Is there a magnifier utility in Windows or is that just in Linux ?
Have you tried playing with the cell size under the map's Cell tab...?
Changed DPI settings in control panel/display to 150. Was 96 by default. I can go to 200 and make it larger again if needed.
Also drop the decimal point, that will make each cell a little smaller.
