Does anyone happen to have the E92? Im wondering if it is the same as the E39.
Also I am looking for the E55, and E83 Diagrams if anyone is able to help.
You can purchase 3 days of access to all GM manuals for $20, from the ACDelco website.
Sign up on a Friday - order in pizza all weekend - and download as many schematics as you would like.
I have access to diagrams through alldata, Im still having trouble getting a couple to communicate
I havent tried the e83, e92 or e39 yet. I have worked on the e55 as well as another Cadillac controller that I dont know the exact controller designation.
I am having trouble getting the e55 and the other Cadillac controller to communicate. I read somewhere that the low speed serial bus in the Cadi controllers wakes up the ecm to allow high speed data. I messed with them last weekend and got nothing out of either of them.
Guess I will just have to keep messing with them. EFI Connection must have figured it out because they sell a harness for the e55.
Are you trying to build harnesses to bench read / flash controllers ?
Yes, I have the pinouts from the computer. hooked up ground, 12v power, ignition voltages and CAN but couldnt get anything out of them. Only ones so far that have given me this much trouble.
For the price EFI Connection charges (Speartech's prices are higher) for their bench harnesses - doing it yourself is not really cost saving - if you factor in materials and all of the time spent.
Just my 2 cents ...
If you have the power (battery and ignition), ground, and CAN High and Low wired correctly, then perhaps you have omitted the Accessory Wakeup input (wire this to 12 volt ignition).
I included it also but cant seem to get it to do a darn thing. I will try again. Maybe im overlooking something.
Went back through everything today and still nothing.
I have attached the pinouts of the one I am working on. Anyone see anything I am missing?
I have......
Connector 1
1- CAN
2- CAN
17 - Switched 12v
18 - Switched 12v
19 - Switched 12v
20 - 12v Battery
46 - switched 12v
Connector 2
73 - Ground
Download station info E78= J1-19=battery pos
J1-20=battery pos
J1-43=can low
J1-29=can high
J2-13=switched 12v+
J2-28=switched 12v+
J2-73= gnd
WORKED FOR ME THANKS
