Commanded Fuel when Cranking
Since the temps are getting colder my car isn't starting up as well now that it is running on e85. It seems as if it needs more fuel when cranking, so I have increased B3604 by about 20 percent. However it seems to make little to no difference. I'm confused on what this table is actually displaying? What are the values in this table?
Mine goes from a vaule down at 1.2 at temps of -40 up to 25. But what are these values exactly? is it eq ratio? the description doesn't really say other than it is the commanded fuel. Is it grams/sec or volume of fuel? is it a/f ratio?????
Also I'm thinking to help cold starts to increase the initial prime when the key is turned on?
