5 out of 5 BBF'es failed. 4 out of 4 PC flashes successful with the Cummins CMB. The most stable I have seen of BBF'ing for Cummins CMB was the July 29th 2011 release.
Thanks,
-Andrew
Thanks,
-Andrew
After the BBF fails (before unplugging the FlashScan/AutoCal), can you please save a trace file on the FlashScan/AutoCal device, then copy the log file to the PC and email it to me at paul@efilive.com. Include a link to this thread so I know what its about, thanks.
LS1B BBF/FF... wow!! :) thanks, I'll be trying this out over the next few days.
http://i601.photobucket.com/albums/t...ll/boostve.jpg
http://i601.photobucket.com/albums/t...creenshot1.jpg
http://i601.photobucket.com/albums/t...creenshot2.jpg
Has appeared on the last couple of RC buids ive loaded on. All were uninstalled and then reinstalled. Ive opened previous tunes iv done a couple of years ago and the BoostVE table appears screwed up as well. I dont remember the BoostVE table reading under 105kpa.
Very weird. The Main VE table reads correctly
Also had a couple of pass thru flashes to the E40 where everything appears to be correct and flash correctly but the g/cyl airflow is very very low when logging. Reflash or Full flash and (sometimes) its fixed and back reading what it should. Not good when it starts trying to command something in the .32g/cyl area under boost
I'm trying to tune a 2012 Turbo Sonic, I can't seem to open the file (Unrecognized PCM) is there a different build I should be looking for to tune this thing or is it still in the works? Thanks
Please send the file that you read from the controller to me at paul@efilive.com
Sorry JezzaB, I forgot we did add a table in to the E40 back in December so the E40 has been modified recently, I'll need to look and see why those tables you showed are all messed up now. Just hold off on tuning that table for the moment, I'm not sure it will be changing the correct data.
