It should be possible, log a support ticket here: https://service.efilive.com/new-ticket
and include the appropriate trace files.
For flashing 2022 CMF (CM2450B) stock files, try this updated version: https://forum.efilive.com/showthread...1-Beta-Release
Note: Please read the "Known Limitations" #2 on that web page about opening CM2450B 2022 files.
Paul 2022 Can we sniff the data going in to a 2020-2021 that locks the ecm down like 2022 and see where they are changing or adding and reverse engineer this possibly?
the same RSA you guys unlocked for 2019-2021............. impossible? no hard on 2022? maybe
If 19-21 can't be read, how does one get a stock ctz file? Can you convert .efd to .ctz?
Most times we can, open a support ticket and attach the *.efd file you want converted.
Is it possible to use a 21 ECM to gain EFI Live support in a '22 Truck ? Or are there additional checksums outside of the ECM that can cause functionality issues with other modules ?
