I have got my built tranny back in but haven't retested as far as the defuel issue. I will try to retest tonight.
I finally got mine to stop defueling I believe the limiter I was hitting ended up being the boost fuel limiter.
Guys, play special attention to your axis's. I fought with this last night before realizing how stupid I was for missing it. Look through your limiter tables and play close attention to the rpm column, you'll see what I saw if you do that.
Nope not my issue, I have gone through ALL limiter tables and have rpm axis up to 4200 and have no commanded fuel limiters under 145, I don't get it, my commanded fuel is getting pulled back and then when it shifts to the next gear it goes up and as rpm increases it drops again....
http://tapatalk.imageshack.com/v2/15...27fe42aeaf.jpg
Green is duration, purple is commanded fuel, each humor where commanded fuel is highest is in the 2600-2900 rpm range
All my limiters are disabled, all my limiter tables go to 4200rpm, and all my limiting tables are set at 145mm^3 above 2600, but I still see commanded fuel being pulled after 2600-2900rpm. any other thoughts?
Boost pressure needs to be less then 50psi including atmospheric pressure. And fuel pressure need to be close to desired.
If the pcm sees 50psi on the map sensor it thanks there a fault. If fuel pressure stays to low it will pull mm3
Less than 50psi in my tuning? Cause my twins are not meant to be under 60psi at wot. Can you go into a little more detail?
Also the fuel pressure, I did put in a Duramax spring in my fuel return valve (12psi rated instead of 18psi) because I have a Duramax as a second pump. So I would decrease it in the table?
EDIT- I See I will alter my axis so that it will not go off the table, aka max my table to 70psj even though I don't think the sensor will read that high
Rescale the boost sensor so it's max boost is 49.
What will that do? My "fuel limiter, boost" table only goes to 32psi, wouldn't I want either the table to either go higher or the boost sensor to read only up to 31psi? Trying to understand this all, thanks
