It has to be modified by the end user.
but it can't be done Dave!!
There are no official details as this would bring a flood of warrenty claims. You have to open it up and work it out as Iam doing...
I didn't say it can't be done? I figured if efi's statement is that they never planned on supporting wideband input then that would be that. Even if the hardware really was technically capable.
As for the warranty claims, easily fixed if efi changes the firmware to disable it all together, but no one is going to want that.
I do genuinely wish you good luck with it though.
There is a thread somewhere here posted a long time ago, I'm looking for it...
WARNING: Opening an AutoCal device will void the manufacturer's warranty.
That said, if you still wish to open your AutoCal to make a serial connection you can do so by connecting to the RX, TX and GND holes on the circuit board as shown in the image below.
Attachment 19030
- Only connect RS232 signals to the RX, TX and GND connector holes.
- DO NOT connect any power source to AutoCal via any of the 5 connector holes.
- DO NOT draw any power from AutoCal from any of the 5 connector holes.
- DO NOT connect anything the the RD\ or VCC connector holes.
The serial interface on AutoCal is functionally identical to the serial interface on FlashScan.
For advanced users, to help debug serial connections there is an option on AutoCal's menu that will dump the RS232 raw binary TX/RX data buffers to a file that can be viewed using a hex viewer tool such as HexWorkshop.
To save the raw data buffers as a *.bin file, start AutoCal in advanced menu mode (hold down the "Next" button while powering up AutoCal), then select "Scan Tool", then scroll down to the "Save COM" option. Use EFILive Explorer to copy the *.bin file to your PC for viewing.
The *.bin file is split into 3 sections:
- $0000..$03FF is the data transmitted by AutoCal to the connected, serial device.
- $0400..$07FF is the data received by AutoCal from the connected, serial device.
- $0800..$0FFF unused.
Any more information on this? I am looking at a PLX wide band and not seeing on the PLX how it would connect to a serial connector.....unless im just not looking at the right thing.
the plx is crap, give up on it and move to a better wideband with proper serial support.
Take a look at the AEM X-series kits.
Alright, such as the AEM or possibly an Innovate? Then just wire in the RX/TX/Ground to the Autocal with a connector, and match it on the wideband controller?
well you really only need the tx from the wideband on the rx of the autocal unit and you'll get wideband data
