Cindy, was any work attempted at connecting with the CAN datalink underhood connector of the 04-05 PCMs? Could it be pinned to pins 6 and 14 of the OBD2 port and communicated with via CAN bus and not legacy SCI?
Yes, in fact that was the path we were heading down rather than the old legacy SCI bus. But it would have been a major (major!) job getting that slow CAN bus protocol in to the software so we decided against it. We were able to talk to the ECM via that port, but it is totally different to the High Speed CAN bus messaging.
GMPX, is it not J1939/11 250k?
Hardware config, the ECM simply doesn't have a 500K CAN port, only 250K. I think it was about 2006 that 500K CAN became mandatory on all vehicles, up to that point OEM's could do whatever they wanted. But the CAN speed was not the issue, see below...
Yes correct (except 29bit) but AFAIK the messaging involved for read/flash via J1939 is Cummins spec, not SAE. If it was SAE then we would could have considered adding it in as all the documentation is available from the SAE.
im new to this game but I have a 05 2500 5.9 and was wondering if efi live is compatable or will be compatable with it anytime soon if so were to get it etc etc we had it on our 04 dmax and from what I can remember you could do a lot that a standard tuner couldn't any advice info etc is appreciated, thank you
When are we getting 03-05 support??
As per the response in your other thread about 15 mins before posting here, EFILive announced it will no longer be seeking to develop support for 03-05 SCI based trucks.
We've invested a couple of thousand development hours into the project without return, and can't see how adding more resources will change that. We made a decision to concentrate on newer platforms, and presently have 2010-15 Cummins in beta.
2010-15 Cummins is scheduled for release in the next few days, and these platforms will consume the best part of the next 12 months of development for enhancements.
So even if we didn't say we were dropping SCI there is simply no development time available in 2015.
Cheers
Cindy
