Hi all
I can do deletes with on lml etc, but when i load stock ctz from cummins i dont have nothing in tables. is there other 3rd software to edit the files for delete and power ?
Hi all
Attachment 23668
This it what i see when i open ctz from cummins, i dont have any maps or system
EFILive has never had parameters to do deletes on these Cummins ECM's.
Yes but it even not open the normal maps boost/timing/torque limiters etc..
Actually that is a bug in the particular version of V7 you have there. You should be getting message that the OS is not supported.
Reason being is Dodge must have replaced it with a newer calibration between EFILive software releases, we don't tend to go back and map every known OS on these ECM's because there is simply too many to do.
