I'm having a peculiar issue, where I can't seem to get the data log to stop. If I click the STOP button, it just sits and won't stop until I shut the car off. Does anyone have any ideas? This is using V7.5.
How are you try to stop the log?
Ok started using V8 Scan, and CTRL-Q appears to work as it should
V8 is same and/or better than V7, the "buttons" are different.
There are a few ways to stop the log in car. One way is to put the car in park and use the emergency brake. Another way is to put the car in neutral and use the emergency brake.
