3 Attachment(s)
CALC.VET Struggles, VE Values Don't Seem Sane
I'm wanting to do a CALC.VET to my 97 dually in signature. While I live in CO, I'm on vacation in MI at a much lower elevation and would really like to clean up the VE and MAF while I'm here. My fuel trims are typically pretty good, but PE fueling doesn't deliver what's commanded so I need to start here first. The only mods to the truck are a slightly larger cam, 42# injectors, and a Whipple supercharger. I tried a CALC.VET here last year with my 1500 and the MAF correction values came out sane, but the VE stuff was telling me I needed to double or triple my VE values. I know they're not that far off. I'm using the stickied tutorial:
https://forum.efilive.com/showthread...in-single-log)
My dually is now telling me to copy/paste with multiply over 3X the present value as well. My OS started life as 12208322, but now is 1270003 so GM.DYNAIRTMP_DMA ought to be defined for it. My Techedge wideband seems to be communicating properly, I put the calc_pids.txt file where I was supposed to, my VE is in g*K/kPa, none of the PIDs have red Xs. . . could this be somehow related to me being 2 bar and not 1 bar? I was able to do this successfully in CO a while ago on my 1500 so not sure what the deal is here today. I've attached a log and the current tune.
Attachment 23862
Attachment 23863
Also, here's the calc_pids file I've been using.
Attachment 23864
I've kept the original as well.
