Is anyone else having this issue?
When you open your tune for LS1B pcm and look at VE while cranking(B0102) it show 0.1, but if you use the compare tool and open a copy of the same tune you will see typical numbers ie 57 even tho it was the same tune,
Is this a glitch in software ?
Attached is example of this, this is the same tune just saved and renamed so it can be loaded as compared
Attachment 23872
Attachment 23873
