Need to make a post
Need to make a post
You should have gotten the 30-0333 if you're running only one wideband; the 30-0334 is the second wideband if you're dunning two widebands.
But it appears the 0334 works by itself.
Post the log files you're getting.
On your AC where/what are the logs being saved to...?
IIRC, The 30-0333 does not support EFILive. Just "Brand H". The 30-0334 was designed to work with EFILive in both single and dual configurations.
Here's the log file. On my autocal, the files are being saved to the scan folder as an .efi file extension.
Even if I use my autocal as a pass through and log with my laptop, I get the same results. If I unhook my autocal, or turn off my car and wait for it to time out and turn off, that's the only way I get the wideband and autocal to talk again, but it's always only for a few minutes.
Joecar did you see anything with my log?
The problem appears to be the data coming from the wide band. The data does not stop abruptly, but ramps up to an invalid/faulty value over a number of frames as shown below. That implies (to me) that the wide band has failed and the output from the wide band has drifted to its maximum value over a sequence of 4-5 frames.
Attachment 22894
Attachment 22895
